johngrady
Sep 09, 2021Aspirant
netgear X4 , starlink
says not compatible , no WPS on starlink , many other devices just hook up with wifi password . Why not this extender Starlink extender needed !!!!! Said nothing about not compatible till after you...
Sep 09, 2021Guru - Experienced User
did you try installing it using the installation assistant?
the EX7300 is an extender only. not a router.
so you need to make sure your starlink router is running (and usable), then set it up using the installation assistant.
microchip8
Sep 09, 2021Master
There is no guarantee the extender will work with Starlink. It's not even certified for it. Next time do a bit of research if you want compatible Starlink devices.
