WebfootMedic
Oct 11, 2021Follower
Netgear X4 AC2200 compatible with the WiFi 6 system?
I apologize if this was answered earlier, but I couldn't find it. Does anyone know if the Nighthawk X4 AC2200 Wifi Mesh Extender is compatible with the Nighthawk Whole Home Mesh Wifi system? I have t...
Oct 12, 2021Guru - Experienced User
what mesh system do you have?
What extender do you have? is it the EX7300 you put in your signature?
If it is, it won't integrate in the system but it can connect and work. It just wont' be as fast and won't roam as well as the mesh system will becuase its not integrated/controlled like the mesh system is.
