jangodog
Jul 21, 2017Aspirant
Netgear X4 or x4s
Hi. Just Got the X4 router and it is up and running. Speed is okay but not as fast as the TP Link ac2600 that i just trade it with. TP Link did around 85-90 MB downstairs from the router and the Nig...
- Jul 24, 2017
Hi. Did just that and the X4S Ninja in Pyjamas is up and running:) Allready i can see performanse boost:). Thank's for your advice on this router question:)
mondenath
Jul 21, 2017Prodigy
You coudl have asked for best one in this forum before going for it.
X4s hands down. its best overall in terms of speed and specs in data and also all round performer and ready for next gen wave 2 full implementation in AC wireless band.
If you can return and get do that immediately. As its an option on few stores like best buy.
jangodog
Ups! Should have asked before purchase :) Maybe i will return it for the X7800.
It will then be the third router install within two weeks:) Thank's for your input anyways
and have a nice weekend :)
- mondenathJul 23, 2017Prodigy
Its R7800. not X . there is C series but it is pure docsis 3.1 . You cant use normal one like ethernet based fibernet.
