duncanbell3
Mar 24, 2020Guide
Netgear X6 AC3200 - which network?
Hi I have 3 networks coming up NETGEAR25 NETGEAR25-5G-1 NETGEAR25-5G-2 Why are there 3 networks and which 1 do I choose to connect to? What would be the best for range? I'm not in a bi...
- Mar 24, 2020
The R8000 supports smart connect (band steering). You can turn that feature on and it sets a single ssid for all 3 bands and lets the router steer devices between the bands as needed.
microchip8
Mar 24, 2020Master
Because this router model is tri-band?
Use a wifi scanner on your phone/laptop and see which radio band gives you the best signal. In general, 2.4 GHz is more about range than throughput, while 5 GHz is the reverse
