duncanbell3
Mar 24, 2020Guide
Netgear X6 AC3200 - which network?
Hi I have 3 networks coming up NETGEAR25 NETGEAR25-5G-1 NETGEAR25-5G-2 Why are there 3 networks and which 1 do I choose to connect to? What would be the best for range? I'm not in a bi...
- Mar 24, 2020
The R8000 supports smart connect (band steering). You can turn that feature on and it sets a single ssid for all 3 bands and lets the router steer devices between the bands as needed.
Mar 24, 2020Guru - Experienced User
duncanbell3
Mar 24, 2020Guide
Awesome, thanks very much.
Just changed it and I'll see hw we go.
Thanks again
