roos5
Oct 01, 2021Guide
Netgear XR1000 upnp not turning on
Hello, I just upgraded my router went from XR500 to XR1000, so far so good. There is only one thing, the UPnP check box donest stay checked, it goes back to uncheck as soon as i hit apply, i assu...
WeatherShip
Oct 15, 2021Tutor
Same here..latest firmware installed......... XR1000 1.0.0.58_1.0.44
Whats up netgear? Cosmetic bug?
I have tried Edge, FF, and Chrome
Oct 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Thank you.
