Boodog
Jul 04, 2017Aspirant
NETGEAR's Alexa Integration
I just purchased the C7000 Netgear modem/router. I thought the C7000 can do what the R7000 can do. But I can't get it to hook up to Alexa. Should I return this one and get the R7000 or is there a way...
- Jul 05, 2017
Thank you, so am I.. :)
William10a
Jul 04, 2017Master
Glad you get it to work wish you good luck.
- BoodogJul 05, 2017Aspirant
