Boodog's avatar
Boodog
NETGEAR's Alexa Integration
I just purchased the C7000 Netgear modem/router. I thought the C7000 can do what the R7000 can do. But I can't get it to hook up to Alexa. Should I return this one and get the R7000 or is there a way...
  • Boodog's avatar
    Boodog
    Jul 05, 2017
    Thank you, so am I.. :)
