duckware's avatar
duckware
Prodigy
Jan 14, 2020
Netgear's 'wireless bridge' DFS CHANNEL blunder
Many Netgear (DFS capable) routers, when configured as a 'wireless bridge', are UNABLE to connect to another Netgear router/AP operating on a DFS channel!
Dustin_V  DarrenM  - Please address and fix this problem.  Someone within Netgear is dropping the ball.  According to filed FCC documents, Netgear is getting many DFS capable routers (even AX ones) certified as a DFS Master, but then failing to get the router also certified as a DFS Slave.  Translation: The router in 'router mode' can use DFS channels, but the router in 'wireless bridge' mode can NOT use DFS channels.
  • Hello Duck
    I will pass this info on to the engineers. Thanks for bringing this up.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Duck
    DarrenM
    • duckware's avatar
      duckware
      Prodigy
      Thanks.  And also pass along the comment that any Netgear router that supports "wireless bridge" (a wifi client, not a router) must be FCC registered as a DFS slave/client -- just as we all expect that any new smartphone will be able to connect to any router (even routers on DFS channels) because the smartphone is FCC registered as a DFS slave/client.
      • DarrenM's avatar
        DarrenM
        Hello Duck
        Can you tell me what Router models you are seeing this on.
        DarrenM
