webalini
Jan 14, 2022Aspirant
Netgeart Nighthawk on 2.4Ghz only-how to activate
I want my nighthawk ot be on 2.4Ghz only. I don't want it on 5Ghz at all. How do I shut off the 5Ghz?
Jan 15, 2022Guru - Experienced User
what router do you have?
Some you can disable smart connect/specific bands. Others you can't.
So an actual model nubmer helps.
