supermario3D1
Sep 02, 2022Aspirant
Netgeat R7000 keeps disconnecting
I have been having issues with my router and originally it keeps disconnecting from wifi, so then i installed version V1.0.9.42_10.2.44 to my router and that has made my 5G wifi disappear, Does anyon...
wcalifas
Sep 02, 2022Prodigy
If it keeps disconnecting and you've tried several of the newer firmwares I'd try an older random firmware and see if that helps things out.
Kitsap
Sep 02, 2022Master
If you are throwing different firmware versions at your router like a blue plate special, you will need to do a full firmware default reset between uploads. After the upload and router boot, let it run for a few minutes and then do a power cord disconnect reboot before testing.
