marcp4726
Apr 08, 2021Aspirant
NETGER AC1200 NOT CONNECTING
I have just purchased the AC1200/EX6120 range extender. i am currently trying to set this up and bottom line is its not working! I am in the same room as my router and i have tried the WPS metho...
Apr 08, 2021Guru - Experienced User
Prior to trying to set it up using the installation assistant, did you factory reset it?
Push and hold reset for 7-15 seconds while its powered on.
Then try using the installation assistant
- marcp4726Apr 08, 2021Aspirant
oh i have only pressed factory rest for a second or two so shall try that.
what's the setup assistant?
- plemansApr 08, 2021Guru - Experienced User
Its the manual install process. The 2nd video in the series demonstrates using it.
https://www.netgear.com/support/product/EX6120.aspx
Oh the factory rest button worked and brought up the NETGEAR wifi.
now for some reason i can get as far as putting in the wifi passcode and it just doesn't connect
