marcp4726
Apr 08, 2021Aspirant
NETGER AC1200 NOT CONNECTING
I have just purchased the AC1200/EX6120 range extender. i am currently trying to set this up and bottom line is its not working! I am in the same room as my router and i have tried the WPS metho...
Apr 08, 2021Guru - Experienced User
Prior to trying to set it up using the installation assistant, did you factory reset it?
Push and hold reset for 7-15 seconds while its powered on.
Then try using the installation assistant
marcp4726
oh i have only pressed factory rest for a second or two so shall try that.
what's the setup assistant?
- plemansApr 08, 2021Guru - Experienced User
Its the manual install process. The 2nd video in the series demonstrates using it.
https://www.netgear.com/support/product/EX6120.aspx
- marcp4726Apr 08, 2021Aspirant
Oh the factory rest button worked and brought up the NETGEAR wifi.
now for some reason i can get as far as putting in the wifi passcode and it just doesn't connect
what router are you connecting it to?
And what area specifically are you talking about? Logging into the extender or actually setting up the routers connection?
