WGJOC
Apr 30, 2019Tutor
Netger R9000 how long to to backup using ReadyShare Vault? It's been running for >20 hours!
I am trying the ReadyShare Vault backup routine on my new NetGear R9000 and just wondered if it should be expected for this to take a LONG time - this is the first backup?
I set it running arou...
- May 01, 2019
> I guess it's possibly backing up somewhere approaching 1TB of data.
> [...]That's not a small amount.
> [...] I'd like to know if this sort of time duration is normal [...]
It may be. You need to consider that you're dealing with the actual
source storage device and the backup software on the Windows system, the
network hardware, the file sharing software running on the
(sub-amazing?) CPU in the router, the USB interface speed, and the
actual destination storage device attached to the router. Many of those
considerations vanish with a destination storage device which is
directly connected to the source system. Without a much more detailed
analysis, I would not bet that the router's USB interface is your
bottleneck.> [...] and if subsequent back-ups are quicker i.e. is it one of these
> systems where subsequent backups only change files that have been
> changed since the last time?
Almost certainly.> [...] NAS [...]
I also wouldn't bet that a "true" NAS system would greatly improve
your times. My NAS experience is limited to small Seagate devices
(NAS 220, and similar -- SATA disks, gigabit Ethernet), and I haven't
done any large transfers to one lately, but I've spent at least a whole
day waiting for an initial (Mac Time Machine) backup (smaller than 1TB)
to finish. Running the experiment would be much more reliable than any
advice you're likely to get here.I _would_ expect a real NAS gizmo to suffer from fewer firmware bugs
than the slapped-together mess of freeware which you'll find for file
sharing on a Netgear router. However, the primary advantage of a real
NAS gizmo is RAID. When your single USB-connected disk fails, you
typically lose all the data on it. When a disk fails in a RAID system,
you don't.
WGJOC
Apr 30, 2019Tutor
It's now up to 24 hours running and still only 68% completed!!!
shadowsports
Apr 30, 2019Hero
Greetings,
You've just learned a valuable lesson. Backing up to USB is the problem. Thats your bottleneck and weak link. Consider another destination like true network attached storage (not network attached USB) and you will be much happier with the results.
- WGJOCApr 30, 2019Tutor
Hi shadowsports many thanks for that - at least my system is not behaving unexpectedly.
However, it begs the question as to why Netgear advocate attaching a diskdrive via USB3 to act in a back-up capacity then supply software that appears to be designed for the task when such a system, would appear from your comments and my experience, to not be efficient.
Perhaps I'll let it complete this time and see where it leaves me, but if it is going to take that long each time it is needed then I think I'll try to sort out another solution. You mention 'true Network Attached Storage' is that these so called NAS drives? Please bear with me - I am on a steep learning curve here - so 'Network attached' does this imply that these are drives hard wired into the network via the router Cat 5 ports or similar ports in an extension box via something like a Cat 5 ethernet cable? I've looked online and found NAS drives listed, but some of these still seem to suggest a USB3 connection where you suggest that USB is the problem.
Would I get a partial solution if the PC I am backing up had a USB3 connection like the R9000 has? Is this something that I could install if the machine motherboard had a spare slot? Would it help, or do I really need this network connection to a drive (presumably through that cat5 ethernet cable I mentioned above)?
- myerswApr 30, 2019Master
NAS stands for Network Attached Storage. It is a device that connects, normally via Ethernet to your network created by your router. Normally connected to one of the Ethernet ports on your router. It appears as another storage device in Windows File Finder. You may need to do a google search as to how, if you do not know how to connect to a network drive.
- shadowsportsApr 30, 2019Hero
They claim print server capability as well... its just a bunch of marketing BS.
What would be better. If Netgear would develop and sell routers with FW that actually works. I'll leave it at that.
