samson22
May 02, 2020Initiate
Netgrear CM500 modem with Nighthawk router
 Hi,  I just bought a new CM500 modem to replace the Comcast Xfinity modem which was leased. The modem was activated successfully with Comcast and I can connect fine to the Internet when I connect thr...
- May 10, 2020I reset the router a few times but nothing worked. Then, I finally changed the Router Mac address settings and set it to "Use Computer MAC Address" in the Internet Setup which resolved the problem. Thanks to all for their advice and help.
May 03, 2020Guru - Experienced User
What router model?
Firmware on the router?
Did you follow this procedure?
shut off modem and router and disconnect devices from both.
power up the modem with only coax and power connected. leave for several minutes.
connect lan cable from modem to wan port on router
power on router. leave it for a few minutes.
then try setup?
