samson22
May 02, 2020Initiate
Netgrear CM500 modem with Nighthawk router
Hi, I just bought a new CM500 modem to replace the Comcast Xfinity modem which was leased. The modem was activated successfully with Comcast and I can connect fine to the Internet when I connect thr...
- May 10, 2020
I reset the router a few times but nothing worked. Then, I finally changed the Router Mac address settings and set it to "Use Computer MAC Address" in the Internet Setup which resolved the problem.
Thanks to all for their advice and help.
michaelkenward
May 03, 2020Guru - Experienced User
Did you reset the router before introducing it to the modem?
samson22
May 10, 2020Initiate
