kbjornfors
Jun 20, 2016Aspirant
Netword Performance issuse
I have a 1000/100 fiber connection to my house and when I connect my laptop direct to the connection point, I get around 980/97 Mbit/s. When I connect the R8000 X6 wan-port to the connection point, ...
- Jun 20, 2016
The problem is solved. There was some issue with the wlan. I have five AP, five switches and one router in my big house. When I reconfigured my r8000 fr.o.m. scratch with another ssid for the wlan and disconnected the rest of the network I got 965 Mbit/s down. Then I carefully configured and connected the other units. Now I have finished the network and the result is stunning. The throughput from internet is better than 950 Mbit/s all over the wired part of the network. Nearly three times what it was when I started.
TheEther
Jun 20, 2016Guru
Is AP Mode enabled?
kbjornfors
