spetrovich55
Oct 12, 2021Aspirant
network issues since updating firmware
Recently I updasted the firmware on my router to V1.0.4.76_10.1.82 and since then my wifes laptop connected to LAN, was blocked for some reason, and still have no clue why. It worked on wifi. I unb...
Hawkv
Oct 24, 2021Aspirant
Since I updated firmware V1.0.4.76_10.1.82 I have nothing but problems. All of sudden Internet access stopps working, I have been rebooting the router once a day to go back. I have Circle 1 enabled and it keeps creating issues. Everything was working fine until this firmware upgrade. Is there a way to down grade the firmware ?
Oct 24, 2021Guru - Experienced User
yes you can downgrade.
Simple go to the support site for your device and click on downloads. Then click on "view previous versions".
Download the version you want, extract it, and follow the manual update process but instead of using newer firmware, you use the firmware you downloaded.
