kotskop
Oct 11, 2021Aspirant
Network key
Hello, I cannot locate the correct network password for my MR60 and all on line documentation refers back to changing passwords on the Netgear support web page which I can log on to, not the issu...
kotskop
Ignore this, I think I understand a hard reset and therefore return to the label network and key is possible if you keep the reset button long enough. It still locked up the router so I pulled the power and put it back in, the routed default to the factory network and key
