jcash
Jan 24, 2024Follower
Network Name Change
If I change the name of my network do I have to re login all my devices or will the router populate the new name to each one?
Jan 24, 2024Guru - Experienced User
If this is changing the wifi SSID name, then yes.
What NG product are you referring too?
- plemansJan 24, 2024Guru - Experienced User
If you're talking about SSID then yes you would.
I have a set ssid/password so whenever I change routers, all my devices just swap over without issues. It works great
