strongarmsps
Jan 12, 2017Aspirant
network printing with nighthawk x 6 tri band
My print is connected to 2.4Ghz wirelessly as this is the only channel is identifies. when my computer is connected to 5 ghz wirelessly it cant print. But connect my computer to 2.4 Ghz and it will...
- Jan 15, 2017
Hi strongarmsps,
1. Check if the printer is getting a valid IP from the router?
2. Reconfigure the printer to connect to the router.
VE6CGX
Jan 12, 2017Master
Can you ping the printer from device on 5GHz? Is the printer configured as network printer?
strongarmsps
Yes the printer is configured as a network printer. And no i cant ping the printer as its always in offline status according the the device.
- JamesGLJan 15, 2017NETGEAR Employee Retired
Hi strongarmsps,
- JamesGLJan 18, 2017NETGEAR Employee Retired
Hi strongarmsps,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
