ashish_shar
Mar 31, 2021Follower
Network Security Key stopped working suddenly
Hello community, My internet connection suddenly stopped working 1 hour ago. It asks me to enter the "network security key". And when I enter it, I get the message: "some information changed since t...
DarrenM
Apr 16, 2021Sr. NETGEAR Moderator
You may want to tell your device to forget the network and try to connect to the wifi again. Or you may want to try the default wifi password which is typically on the bottom of the router on a sticker.
DarrenM
