dusty14
Dec 20, 2018Aspirant
Network Security key
The internet access on my windows 10 computer is asking for the network key to connect to two items. One is my Canon printer and the other one is Roku. I enter the network key but it is not accepte...
- Dec 21, 2018
dusty14 wrote:
Yes, it just like the example that you have shown. So I guess my printer and Roku are transmitting and just ignore it? I don't it can be coming from outside my house, for example, a commercial area as I live in the country in a wildlife management area. Certainly no distinctly next door neighbors. So I am thinking I should just ignore it.
Yes I would ignore. The printer and Roku are working normally. You would not be able to send documents to the printer from a network connection if it did not make itself known for example. All part of interconnecting of things.
dusty14
Dec 21, 2018Aspirant
I don't believe I can take a screenshot of it. However, in the taskbar on the bottom of the screen on the right hand side is an icon that I click on that raises a small picture where I can click to connect or disconnect to the internet. In the past, it has listed just the Netgear05. I click on it to connect or disconnect as the case may be. Now it has the other two line items that I have mentioned. I hope this explanation helps as I don't know this real name of this small picture that pops up when I click on the icon in the taskbar.
IrvSp
Dec 21, 2018Master
You are on W10 probably. Those are the POSSIBLE SSID connections. Some printers transmit that.
I assume you mean a list like the one attached on the right? This is a list of local SSID's I can see. When I go out to some places I do see PRINTER's. Check its manual for HOTSPOT or something similar.
- dusty14Dec 21, 2018Aspirant
- myerswDec 21, 2018Master
