dusty14
Dec 20, 2018Aspirant
Network Security key
The internet access on my windows 10 computer is asking for the network key to connect to two items. One is my Canon printer and the other one is Roku. I enter the network key but it is not accepte...
- Dec 21, 2018
dusty14 wrote:
Yes, it just like the example that you have shown. So I guess my printer and Roku are transmitting and just ignore it? I don't it can be coming from outside my house, for example, a commercial area as I live in the country in a wildlife management area. Certainly no distinctly next door neighbors. So I am thinking I should just ignore it.
Yes I would ignore. The printer and Roku are working normally. You would not be able to send documents to the printer from a network connection if it did not make itself known for example. All part of interconnecting of things.
IrvSp
Dec 21, 2018Master
You are on W10 probably. Those are the POSSIBLE SSID connections. Some printers transmit that.
I assume you mean a list like the one attached on the right? This is a list of local SSID's I can see. When I go out to some places I do see PRINTER's. Check its manual for HOTSPOT or something similar.
dusty14
Dec 21, 2018Aspirant
- myerswDec 21, 2018Master
