PW05's avatar
PW05
Never seemed to work properly
I have had this for a few years now and it has never seemed to be of any benefit just using electricity in the corner. I recently received an email about a Firmware update so after a great deal of tr...
  • plemans's avatar
    Jan 25, 2022
    Then factory reset it and start over.
    Push and hold reset for 7-15 seconds while its powered on.
    then follow the install guide and use the installation assistant method and NOT wps.
