Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
Bill-D
Mar 01, 2022Apprentice
My R7000 has been solid since updating to v134 from v130 several days ago. To avoid the kind of trouble I've had after previous updates, I did a factory reset before and after installing v134 and then manually entered all my configuration including my 29 reserved IP addresses.
Mar 01, 2022Guru - Experienced User
