Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
ngnighthawk
Mar 12, 2022Tutor
Thank you for your response. QoS is already off but I'm not truing WMM turned off as well. I've seen other posts here though recommending that WMM be turned on, I'll try with it off and report back.
ngnighthawk
Mar 12, 2022Tutor
ngnighthawk wrote:Thank you for your response. QoS is already off but I'm not truing WMM turned off as well. I've seen other posts here though recommending that WMM be turned on, I'll try with it off and report back.
Update: confirming that there's no change in 5GHz behavior with or without WMM off.
