Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
Sinnis
Mar 20, 2022Aspirant
I encountered 2 GUI problems after flashing v134:
- Admin tab not working correctly just like Bob mentioned.
- CPU load percentage bar not showing up. In the debug page, it showed up without error.(check attatched screenshot)
Apparently there's something broken in the backend concerning the web pages.Other than that, everything works OK. WiFi works fine and I had smart connect enabled.I did a reset before and after flashing the FW.
Since these are all minor issues and considering the variety of problems reported in this thread, I decided not to flash another FW for now. Hopefully it will get fixed in future updates.
- GregGregMar 21, 2022Star
The admin tab did not work properly on the earlier firmware version.
But it depended on the browser manufacturer and its version. On some browsers it worked properly, and on some browsers this page was displayed badly.
- FURRYe38Mar 21, 2022Guru - Experienced User
What browser are you using? Be sure to clear out all browser caches. Try different browsers as well.
Not seeing any Advanced tab problems with mine when I had it online.Possible NG removed the percentage bar from recent FW versions.
Since these are all minor issues and considering the variety of problems reported in this thread, I decided not to flash another FW for now. Hopefully it will get fixed in future updates.- SinnisMar 21, 2022Aspirant
I did reset and setup everything manually after upgrading from 1.0.11.128. I tried Chrome(Version 99.0.4844.82 (Official Build) (64-bit)) and Edge (Version 99.0.1150.46 (Official build) (64-bit)), both are having the same problems. I also tried browsing the admin page as guest and incognito. Clearing caches didn't work. Sometimes the tab is OK, I'd say there's a 50-50 chance that the tab will switch normally. Whereas the percentage bar is constantly failing to display. Can't understand why would they remove that.
