Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
Sinnis
Mar 20, 2022Aspirant
I encountered 2 GUI problems after flashing v134:
- Admin tab not working correctly just like Bob mentioned.
- CPU load percentage bar not showing up. In the debug page, it showed up without error.(check attatched screenshot)
Apparently there's something broken in the backend concerning the web pages.Other than that, everything works OK. WiFi works fine and I had smart connect enabled.I did a reset before and after flashing the FW.
Since these are all minor issues and considering the variety of problems reported in this thread, I decided not to flash another FW for now. Hopefully it will get fixed in future updates.
GregGreg
Mar 21, 2022Star
The admin tab did not work properly on the earlier firmware version.
But it depended on the browser manufacturer and its version. On some browsers it worked properly, and on some browsers this page was displayed badly.
