Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
Mar 21, 2022Guru - Experienced User
What browser are you using? Be sure to clear out all browser caches. Try different browsers as well.
Not seeing any Advanced tab problems with mine when I had it online.
Possible NG removed the percentage bar from recent FW versions.
Sinnis wrote:
I encountered 2 GUI problems after flashing v134:
- Admin tab not working correctly just like Bob mentioned.
- CPU load percentage bar not showing up. In the debug page, it showed up without error.(check attatched screenshot)
Apparently there's something broken in the backend concerning the web pages.Other than that, everything works OK. WiFi works fine and I had smart connect enabled.I did a reset before and after flashing the FW.
Since these are all minor issues and considering the variety of problems reported in this thread, I decided not to flash another FW for now. Hopefully it will get fixed in future updates.
Sinnis
Mar 21, 2022Aspirant
I did reset and setup everything manually after upgrading from 1.0.11.128. I tried Chrome(Version 99.0.4844.82 (Official Build) (64-bit)) and Edge (Version 99.0.1150.46 (Official build) (64-bit)), both are having the same problems. I also tried browsing the admin page as guest and incognito. Clearing caches didn't work. Sometimes the tab is OK, I'd say there's a 50-50 chance that the tab will switch normally. Whereas the percentage bar is constantly failing to display. Can't understand why would they remove that.
- FURRYe38Mar 21, 2022Guru - Experienced User
I'll check mine again. I haven't seen this issue. I ran my R7000 for a good week or so and worked well.
I'll check the Advanced tab and debug pages.
You might want to try a re-load of the FW on to the router, after FW is loaded, factory reset and setup from scratch and see.
Possible removal reasons is that it's something that's not used much by users and taking up FW resources that NG deemed not necessary as the visual gas gauge is represented by text values seen on the debug page which is what NG seems to be keeping as standard across multiple product lines. We only see the text values on this page for most NG products.- SinnisMar 21, 2022Aspirant
Wow thanks for the informative info. I just tried newly installed Firefox ESR, didn't work :(.
As for the re-load, I won't be able to do that very soon. Since last time I loaded the FM caused a few hours without internet connection, got quite a lot of complaints from my family.- FURRYe38Mar 21, 2022Guru - Experienced User
