Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
Feb 28, 2022Guru - Experienced User
Wired WAN to LAN speeds are still good here:
Mar 23, 2022Guru - Experienced User
I checked my R7000 today and I can access the Advanced Tab and pages fine: MS Edge
No modification of the web page code either from the console. Though I do notice same code you found. Another item I found is a title listing for a WNDR3400 in the code. Found that kind of odd.
- SinnisMar 24, 2022Aspirant
From your screenshot, I see that you don't have any percentage bars in the admin page. How strange. I'm wondering if you had missed any updates on R7000? Did you keep a record of your update sequence?
I had been running the Merlin FW since 2016 when I bought the router. Until a couple of months ago, my r7000 started to randomly reboot every 3-4 days, flashing back to the stock FW (from V1.0.3.24_1.1.20 to V128) fixed the problem. 0 spontaneous reboots after that. I still had the cpu percentage bar on v128. It could be missing some of the FW in between causing the GUI issue.
- FURRYe38Mar 24, 2022Guru - Experienced User
What percentage bars are you referring to? Please post a screen capture of this. As far as I know there hasn't been any percentage bars on this page whatsoever on stock NG FW.
Merlin FW on the R7000? Do you mean the ASUSMerlin 3rd party FW? That's a completely different FW and UI and not officially supported here.
This router has only run stock and was given to me a couple of years ago as my work didn't need it anymore and phased stuff out so I took it home. I believe it had a v.30ish something when I got it. I loaded it up with what was available back then. I had v.34 loaded on it last year I believe then decided to jump to most current and see if any problems are seen. So far, when i had the router running, ran great. No issues. The only issue is with the NH app can't get logged in. Something I passed to NG for review.
I am talking about the RAM and CPU percentage bar. You can find the screenshot at message#20 in this thread. If I remember correctly, I did had those even before flashing Merlin. I understand that 3rd party FW is unsupported here, but now that I'm back to the stock FW, I feel like I can be supported. Anyway thanks for the detailed description.
