Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
jdenman03
Apr 05, 2022Star
I would think that too, but there are a lot of people like me on the forums with the same issue. And I find it odd that I can go to 9.42 and have virtually 0 problems. And I have little to no problems on firmware prior to 9.42. Check out the problems when 9.88 came out. I remember it vividly at the time because it killed my 5Ghz band. Ended up dropping back down to 9.34 for 2 years (until now) and when this firmware did the same thing, I went back down to 9.42.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-firmware-1-0-9-88-10-2-88/m-p/1868382
Guilden-NL
Apr 19, 2022Tutor
Exactly the same for me. gave it 24 hours but it's so miserable, so I too dropped back to 9.34
It's been long enough, I don't want to risk security, so I will be buying another brand and recycling this one by ripping it apart and recycling non-electronic stuff, while board and chips, etc, will go into our community hazmat. My old Linksys WRT54G running DDWRT I use out in a barn is better than this junk.
- FURRYe38Apr 19, 2022Guru - Experienced User
Have this loaded on my R7000 and ran well for the full week I had it online as main host router:
Seeing no issues with 5ghz. Manual channel 1 and 48 or 149. Smart Connect and WMM enabled. QoS disabled. 40Mhz only.
