Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
May 02, 2022Guru - Experienced User
Have you tried manually updating FW as mentioned in the first post?
catik wrote:
language version stay V1.0.11.120_2.1.38.1, cannot update?
I have tried change to other languages, all are stay behind.
I checked update, and there is no new firmware available.
catik
May 02, 2022Star
Yes,I manually updated FW from 126 to 134, I never use automatically update.Then I reset to factory settings several times by click erase or push reset button, and then recheck FW update.
- FURRYe38May 02, 2022Guru - Experienced User
If your at v.134 now then you'll be current then.
- catikMay 02, 2022Star
FURRYe38 wrote:If your at v.134 now then you'll be current then.
catik wrote:Yes,I manually updated FW from 126 to 134, I never use automatically update.Then I reset to factory settings several times by click erase or push reset button, and then recheck FW update.
Well, so, GUI languages lag behind FW, I will wait.
Another problem, when ARP protection/IP MAC Binding (ADVANCED->Security) turned on, there is no connection, and I cannot log into router, I have to push reset button . This problem keeps existing from 1.0.9.88, and never be solved.
BTW,
bug 1, CPU Load only shows "%".
bug 2, After changing language from up right corner, BASIC page and ADVANCED page show in one page split apart horizontally.
- GregGregMay 03, 2022Star
Regarding to Your question about language firmware version:
The last big change in the functionality of the firmware for R7000 router was in version 1.0.9.88. Then next versions fixes security vulnerabilities (I based on change log in version description).
Language firmware is updated automatically from Internet after upgrade router firmware. Based on info in file: https://http.fw.updates1.netgear.com/r7000/ww/fileinfo.txt (this location is inside router firmware).Last version of language firmware is R7000-V1.0.11.120_2.1.38.1
I haven't checked it, but everyone who has firmware version 1.0.9.88 or higher will have V1.0.11.120_2.1.38.1 language firmware version.
