Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
catik
May 02, 2022Star
FURRYe38 wrote:If your at v.134 now then you'll be current then.
catik wrote:Yes,I manually updated FW from 126 to 134, I never use automatically update.Then I reset to factory settings several times by click erase or push reset button, and then recheck FW update.
Well, so, GUI languages lag behind FW, I will wait.
Another problem, when ARP protection/IP MAC Binding (ADVANCED->Security) turned on, there is no connection, and I cannot log into router, I have to push reset button . This problem keeps existing from 1.0.9.88, and never be solved.
BTW,
bug 1, CPU Load only shows "%".
bug 2, After changing language from up right corner, BASIC page and ADVANCED page show in one page split apart horizontally.
May 03, 2022Guru - Experienced User
BTW,
Heres mine in MS Edge:
What languages are you changing to and from? Post a screen capture if what your seeing.
Mine switched to Spanish:
