Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
May 03, 2022Guru - Experienced User
catik wrote:
Well, so, GUI languages lag behind FW, I will wait.
Another problem, when ARP protection/IP MAC Binding (ADVANCED->Security) turned on, there is no connection, and I cannot log into router, I have to push reset button . This problem keeps existing from 1.0.9.88, and never be solved.
BTW,
bug 1, CPU Load only shows "%".
Heres mine in MS Edge:
bug 2, After changing language from up right corner, BASIC page and ADVANCED page show in one page split apart horizontally.
What languages are you changing to and from? Post a screen capture if what your seeing.
Mine switched to Spanish:
calli
May 04, 2022Guide
