Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
Bob254
Feb 20, 2022Guide
Upgraded from 1.0.11.130 to 1.0.11.134. Update was performed using a PC wired to the router (I do not use their app). The upgrade process went through without a hitch, router rebooted and came back online.
The post-upgrade experience however was not pleasant. Experienced connection timeouts to websites (Google, for example) and, laggy Wi-Fi (2.4 Ghz, I don't use 5 Ghz, it's disabled). Tests were run using wired and wireless connections. Behavior was the same. Timeouts and lag was not specific to any on website, it was random.
Reverted back to 1.0.11.130 and everything went back to normal. Performed a hard reset just to be safe. Running smooth with 1.0.11.130 now.
The Advanced tab of the Admin page (192.16.1.1) appears to be screwed-up in firmware version 1.0.11.134. At least, it was for me. Clicking on the Advanced tab displays the Menu from the Basic tab, then an image that plugs their app and finally, the Advanced tab's menu options are displayed below the image. Tested using Firefox and Edge, the result was the same. After reverting to 1.0.11.130, menu options are back their respective tabs. Curious to see if anyone else experiences this.
Prior to 130, the router was rock solid on 1.0.11.128. Never had any hiccups with 128. I did have one spontaneous router reboot on version 1.0.11.130 about a week after updating to that version. Haven't had the happen since so I'm sticking with 1.0.11.130 for now.
REC0N
May 19, 2022Tutor
Web Gui screwed up the layout in advanced tab. The iframe is to small.
It shows only very few in height especially on tablets.
The iframe height needs to be corrected.
Everything else works fine and after switching German Language to English and back that it updates the language pack's include English, most other layout errors was fixed.
Online search for update did not find this updated Firmwareversion but upload manually worked just fine.
Nice to see updates from time to time for this router. Thanks!
- FURRYe38May 19, 2022Guru - Experienced User
There a screen capture of what your seeing?
- REC0NMay 19, 2022Tutor
I corrected it with an browser script on client side which makes iframes resizable.
The other layout problems solved by switching the language so that it updates the language files.
