Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
May 19, 2022Guru - Experienced User
There a screen capture of what your seeing?
REC0N wrote:
Web Gui screwed up the layout in advanced tab. The iframe is to small.
It shows only very few in height especially on tablets.
The iframe height needs to be corrected.
Everything else works fine and after switching German Language to English and back that it updates the language pack's include English, most other layout errors was fixed.
Online search for update did not find this updated Firmwareversion but upload manually worked just fine.
Nice to see updates from time to time for this router. Thanks!
REC0N
May 19, 2022Tutor
I corrected it with an browser script on client side which makes iframes resizable.
The other layout problems solved by switching the language so that it updates the language files.
