Feb 16, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.134 Released
Security Fixes: 02/16/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link:
https://w...
borijess3
Jul 21, 2022Aspirant
I tried the latest and had drop outs right away. I want to know from the community which software version can I revert back to that will give me the best stability and speeds. I currently have 900mbs DL speed and do not get even close.
- FURRYe38Jul 21, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update?
Be sure to not enable Armor, Circle or Traffic Meter.
I never saw any crashes durinng a full week that I ran it on my R7000:
- Broken-arrowJul 28, 2022Aspirant
I was on update 1.0.9.88_10.2.88 and now update to 1.0.11.134_10.2.119 has lots of issues when power or internet led turn orange and needed restart it (is way I try to update it).
Hope this update fix it (way I was on so old update was because my router not find any new update and today I look on the site).
So fare no issues (but will probably know soon :)) When both this It was really bad (was bug in the firmware so it consistency lose connection (has to want on fix for weeks)).
- FURRYe38Jul 28, 2022Guru - Experienced User
What CAT# lan cable are you using between the modem and router? CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
