Aug 02, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.136 Released
Bug Fixes: 07/29/2022
Fixes the issue where DHCP reservation can only support 62 addresses.
NOTE: IF DNS issues are seen with this version of FW, please enable IPv6 protocols on the router. ...
Spendor
Aug 18, 2022Guide
just like previous version, it only stayed connected for several hours then stopped connection. this bug that exists in all version later than 42 has never been fixed.
- FURRYe38Aug 18, 2022Guru - Experienced User
What was the LED indication on the top of the router when this happened?
What CAT# lan cable are you using between the modem and router?
What devices do you have all connected?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
I didn't see this with mine:
- SpendorAug 18, 2022Guide
i use r7000 as 5GHz AP.
What is the Mfr and model# of the host router that the NG router is connected too?
I use mine in in wireless bridge mode currently. Been working fine for about a week now.
- Greg007Aug 26, 2022AspirantThis may sound crazy but I was having the dropping problem . I went back to my old firmware because of the dropping wifi issues. The next day I tried .136 again and then I installed it a second time right over the top of the first one immediately and everything works. I had tried .136 three times previously with bad results.
Only this I am having a issue with now is that I can't install the nighthawk app on my cell because of a timeout message but my r7000 has been working flawlessly for 3 days.- FURRYe38Aug 27, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? This is recommended if you run into any problems after updating FW.
For any NH app problems, please post here:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
