Aug 02, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.136 Released
Bug Fixes: 07/29/2022
Fixes the issue where DHCP reservation can only support 62 addresses.
NOTE: IF DNS issues are seen with this version of FW, please enable IPv6 protocols on the router. ...
Spendor
Aug 18, 2022Guide
just like previous version, it only stayed connected for several hours then stopped connection. this bug that exists in all version later than 42 has never been fixed.
Aug 18, 2022Guru - Experienced User
What was the LED indication on the top of the router when this happened?
What CAT# lan cable are you using between the modem and router?
What devices do you have all connected?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I didn't see this with mine:
- SpendorAug 18, 2022Guide
i use r7000 as 5GHz AP.
- FURRYe38Aug 18, 2022Guru - Experienced User
What is the Mfr and model# of the host router that the NG router is connected too?
I use mine in in wireless bridge mode currently. Been working fine for about a week now.
