Aug 02, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.136 Released
Bug Fixes: 07/29/2022
Fixes the issue where DHCP reservation can only support 62 addresses.
NOTE: IF DNS issues are seen with this version of FW, please enable IPv6 protocols on the router. ...
Aug 18, 2022Guru - Experienced User
What was the LED indication on the top of the router when this happened?
What CAT# lan cable are you using between the modem and router?
What devices do you have all connected?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I didn't see this with mine:
Spendor
Aug 18, 2022Guide
i use r7000 as 5GHz AP.
- FURRYe38Aug 18, 2022Guru - Experienced User
What is the Mfr and model# of the host router that the NG router is connected too?
I use mine in in wireless bridge mode currently. Been working fine for about a week now.
