Aug 02, 2022Guru - Experienced User
New - R7000 Firmware Version 1.0.11.136 Released
Bug Fixes: 07/29/2022
Fixes the issue where DHCP reservation can only support 62 addresses.
NOTE: IF DNS issues are seen with this version of FW, please enable IPv6 protocols on the router. ...
Hot54321
Dec 29, 2023Apprentice
Hi all,
Is the this 1.0.11.136 Released the last firmware for the R7000?
Also is the R7000 end of life?
Currently im running Firmware Version
V1.0.11.128_10.2.112 and its smooth. But ofcourse I want the latest firmware to feature proof.
michaelkenward
Dec 29, 2023Guru - Experienced User
- Hot54321Dec 29, 2023Apprentice
I cant find the R7000 in the spreadsheet: https://downloads1.netgear.com/files/netgear/documents/SMB_EOL_Product_List_Sep2023.pdf
CTRL+F :R7000 or 7000 = zero hits / 0 hits, its not listed there.
- michaelkenwardDec 30, 2023Guru - Experienced User
Either it is not EOS or it has yet to find its way into that list. In either case, only Netgear knows the status.
Why do you ask?
You have the latest firmware and all is running smoothly.
If you have a security concern, you can always pass it on to Netgear:
NETGEAR Product Security | NETGEAR
