Feb 13, 2024Guru - Experienced User
New - R7000 Firmware Version 1.0.11.216 Released
Enhancement: 02/05/2024
Ending ReadyCLOUD service for WiFi routers.
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, ...
Bob254
Apr 13, 2024Guide
Anyone know why Netgear's support portal now lists 1.0.11.136 on the download page as being the latest firmware version for the R7000?
Download Center | Downloads and Documentation | NETGEAR
Was there an issue with versions beyond 1.0.11.136 that requires firmware to be reverted to 1.0.11.136?
JayVtec
Apr 15, 2024Aspirant
I can only see .136 as being the latest firmware.
- FURRYe38Apr 15, 2024Guru - Experienced User
I see that v.216 is missing and v.136 is at the top and current, though dated from two years ago. 🤔
I'm checking on this with NG.
Ok, so this version.216 is in responce to a security issue found by NG and resolved:
NG recommends installing this version however it's not currently available for download. NG will check into this.
In mean time, users can check for this version of FW thru the routers web page and get it thru there if you choose to update the router.
https://kb.netgear.com/24217/How-do-I-check-for-new-firmware-and-update-my-Nighthawk-router
- JayVtecApr 15, 2024Aspirant
Thanks, Updates will continue to be pushed to the router UI when available in the future?
