Feb 13, 2024Guru - Experienced User
New - R7000 Firmware Version 1.0.11.216 Released
Enhancement: 02/05/2024
Ending ReadyCLOUD service for WiFi routers.
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, ...
Apr 15, 2024Guru - Experienced User
Should be available now if you check thru the routers web page.
JayVtec
Apr 15, 2024Aspirant
I can't just yet, I have just bought one off EBAY so was just going to download ahead of time and flash it/ set it up, before plugging it in. đ
- FURRYe38Apr 15, 2024Guru - Experienced User
Ya checking mine and doesn't find anything. But NG gave me this:
https://kb.netgear.com/000066008/R7000-Firmware-Version-1-0-11-216?language=en_US
Get it while it's hot. đ
- JayVtecApr 15, 2024Aspirant
Got it, Nice one thanks!
I assume it's all good and safe to use?
I had a R7000 not long after they was released, Bought one in 2014, had it for years and regret getting rid of it.
Just hope it holds up to todays online demands.
Just loaded it on my R7000 and running with it now.
I think there maybe some odd issues for wireless bridge mode. I know prior versions, wireless bridge mode would fail after a period of time. I can't test that right now.
It's up and running in router mode for now.
Wired PC speed results behind a CM3000 modem. 1Gb/50Mbps ISP service:
OK, Mine will be in router mode, so all good there.
You can't argue with them speeds can you.
If only i had those speeds. ha
- Bob254Apr 16, 2024Guide
Thank you for verifying this. Much appreciated. I was concerned NG pulled 216 perhaps because it was a hacked version. Just speculation on my part, there's no evidence to support that theory.
I've been running 216 from about a week after it was released back in Feb. Have not had any issues with it thus far.
- FURRYe38Apr 16, 2024Guru - Experienced User
No hacking here. I think NG recently changed the support WEB ui look and feel and maybe something just got left off the plate. I see now that this version has not returned to the R7000 download web page.
Enjoy.
