Feb 13, 2024Guru - Experienced User
New - R7000 Firmware Version 1.0.11.216 Released
Enhancement: 02/05/2024
Ending ReadyCLOUD service for WiFi routers.
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, ...
Apr 15, 2024Guru - Experienced User
Ya checking mine and doesn't find anything. But NG gave me this:
https://kb.netgear.com/000066008/R7000-Firmware-Version-1-0-11-216?language=en_US
Get it while it's hot. đ
JayVtec
Apr 15, 2024Aspirant
Got it, Nice one thanks!
I assume it's all good and safe to use?
I had a R7000 not long after they was released, Bought one in 2014, had it for years and regret getting rid of it.
Just hope it holds up to todays online demands.
- FURRYe38Apr 15, 2024Guru - Experienced User
Just loaded it on my R7000 and running with it now.
I think there maybe some odd issues for wireless bridge mode. I know prior versions, wireless bridge mode would fail after a period of time. I can't test that right now.
It's up and running in router mode for now.
Wired PC speed results behind a CM3000 modem. 1Gb/50Mbps ISP service:
- JayVtecApr 15, 2024Aspirant
OK, Mine will be in router mode, so all good there.
You can't argue with them speeds can you.
If only i had those speeds. ha
