Feb 13, 2024Guru - Experienced User
New - R7000 Firmware Version 1.0.11.216 Released
Enhancement: 02/05/2024
Ending ReadyCLOUD service for WiFi routers.
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, ...
JayVtec
Apr 15, 2024Aspirant
Got it, Nice one thanks!
I assume it's all good and safe to use?
I had a R7000 not long after they was released, Bought one in 2014, had it for years and regret getting rid of it.
Just hope it holds up to todays online demands.
Apr 15, 2024Guru - Experienced User
Just loaded it on my R7000 and running with it now.
I think there maybe some odd issues for wireless bridge mode. I know prior versions, wireless bridge mode would fail after a period of time. I can't test that right now.
It's up and running in router mode for now.
Wired PC speed results behind a CM3000 modem. 1Gb/50Mbps ISP service:
- JayVtecApr 15, 2024Aspirant
OK, Mine will be in router mode, so all good there.
You can't argue with them speeds can you.
If only i had those speeds. ha
