Feb 13, 2024Guru - Experienced User
New - R7000 Firmware Version 1.0.11.216 Released
Enhancement: 02/05/2024
Ending ReadyCLOUD service for WiFi routers.
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, ...
RiRouter
Jun 05, 2024Aspirant
All,
Does anyone know why the Netgear App does not recognize there is a new update so it can be uploaded via the app? The last two updates did not show up in the app and I only discovered them after having issues with the router. This should be unnecessary if the app has a "CHECK FOR UPDATES" function.
Would this happen to be because you need a paid subscription even though updates are not part of the ProSupport Subscription? Thoughts?
Subscription details: https://www.netgear.com/home/services/prosupport/
Rest easy, knowing you're covered
Get total peace of mind knowing that your NETGEAR device is protected for the long run. With ProSupport, you are a VIP. Enjoy 24/7 priority access to tech support from NETGEAR experts, plus accidental damage coverage, and express replacement in the event of an issue.
NETGEAR ProSupport extends your coverage beyond our complimentary 90-day tech support and limited 2-year warranty, giving you VIP coverage.
Thank you.
Jun 05, 2024Guru - Experienced User
I don't think NG is putting FW up on there auto update services for the R series anymore. If new FW comes out, has to be manually applied.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
