Mar 21, 2022Guru - Experienced User
New - R7000P Firmware Version 1.3.3.148 Released
Security Fixes: 03/16/2022
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Download Link: https://www.netgear.com/support/product/R7000P#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/R7000P.aspx#docs.
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how this version of FW works for you...
- ALONSO_GARCIAAspirant
Hello Everyone, i have seen several and several topics about the R7000P droping the wifi several times. I am really tired of this situation, y really messes around with my home office job. I disabled the MIMO functionality and for some time, it gets stable but fails after some demand from my devices (2 phones, 1 laptop, 1 tablet). Have anyone found the right firmware/solution? I will try to put this new firmware and any ideas will be welcome. Have a good one!!!
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?How is the Advanced Wifi settings configured?
Is Smart Connect enabled?
Is Armor, Access Controls, QoS or Traffic Meter enabled?
Be sure to factory reset and setup from scratch after loading FW.
- -Access Control
-Editing device names
-Setting static IPs
If this was a security update that worries me cause the most basic functions don't even work.....some of the tabs crash when editing settings.....installed clean did not use a configuration backup....craziness, get on it please.
