Aug 17, 2022Guru - Experienced User
New - R7000P Firmware Version 1.3.3.152 Released
Security Fixes: 08/04/2022
- Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/
Enable IPv6 Auto if you continue to see DNS Probe or Proxy messages in browsers.
Download Link: https://www.netgear.com/support/product/R7000P#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/R7000P.aspx#docs.
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Let us know how this version of FW works for you...Is DNS fixed for you on this version of FW?
- PaulGoLuminary
Unfortunately this firmware version does not have the fix to correct using Comcast's IPv6 that uses vCMTS. According to Netgear the fix for vCMTS wiith Comcast will be available in firmware released in September.
OK, thank you for letting us know.
- ol_dusty_routerAspirant
1.3.3.154 for R7000p is available now. Release notes just says: "Fixes security vulnerabilities".
Anyone try it yet? Is it stable?
