Oct 23, 2022Guru - Experienced User
New - R7000P Firmware Version 1.3.3.154 Released
Security Fixes: 10/12/2022
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Enable IPv6 Auto if you cont...
PaulGo
Oct 25, 2022Luminary
In order to enable IPv6 with Verizon FiOS you need to use Auto Config which will give you a LAN IPv6 address. The WAN IPv6 address is not shown. If you try Auto Detect it will default to 6to 4 tunnel. I did notify Netgear about this but so far it has not been implemented. Perhaps as IPv6 becomes implemented over more of the area that Verizon serves Netgear will correct this.
- PaulGoOct 25, 2022Luminary
Along with my R7000P router I also have the RAX45 router. With the current firmware both still drop IPv6 after an hour or two if you have vCMTS with Comcast. Originally Netgear stated a fix would be released in September, but the R7000P latest firmware still does not have this update. Netgear now states that an update to resolve this issue for my RAX45 (and other models that use the same firmware) should be released in November. Hopefully the next update for the R7000P will also have this update.
- PaulGoOct 27, 2022Luminary
A follow-up on using IPv6 with Verizon FiOS. It appears Auto Config is just a temporary solution only supplying IPv6 for a short period of time. The Netgear IPv6 page still shows a LAN IPv6 address but using an IPv6 test in my browser no longer shows an IPv6 address and the test fails. Currently the only stable solution for using IPv6 is using DD-WRT which with a 56 prefix gives both a WAN and LAN address. Has anyone has been able to get Verizon FiOS IPv6 to work with Netgear firmware?
